Unitrunker-fresh start?
radsmachine
Mississippi
How do I re-set this back to "factory"? I've torn it up pretty bad. I've tried to un-install and then re-install. All of my settings are still right there where I left 'em.
maus92
OCMD
Use the uninstall function in Windows then reinstall the program.
maus92
OCMD
Then you actually did tear it up bigly. Since we cannot see what you did, it’s hard to help. Good luck.
Enjoi19
Ontario, Canada
I believe Unitrunker stores data in your roaming folder.
Not at a Windows PC with it installed currently but look somewhere under...
C:\Users\YourName\AppData\Roaming\Unitrunker
If you are having trouble getting there, put %AppData% in the URL bar of Explorer and it'll get you in that direction.
If you need further support with Unitrunker I'd suggest going to the Google group.
nd5y
Wichita Falls, TX
The settings are in a Unitrunker folder in your home (user) folder. If you delete that it should start from scratch the next time you run it.
I don't know which version of Unitrunker or Windows you have so I don't know the path to the folder.
Screenshot is the location of Unitrunker folder, Windows 11 and previous versions.
Use the Windows search feature.
Type in:
APP Data.
Roaming Folder
The location is normally hidden.
radsmachine
Mississippi
Thanks for the info. Finding the roaming data was key in getting it cleared. I still cant get it to function properly so I'll just stick with SDR-Trunk.
