Unitrunker help...
APX8000
Sarcastic Member
AES-256 secured
Trying to set up Unitrunker through the PSR-500 using the PC/IF to USB. On the receiver window, it will not let me select anything other than COMM0 for the port. Any ideas?
Jay911
Bragg Creek, Alberta
Have you plugged in the USB cable before you started UT? Are the drivers installed? (i.e. can you upload/download to/from this scanner using programming software?)
After you plug in the USB cable, and before you start UT, hit Windows+Break on your keyboard and find your way to the Device Manager. Open up "Ports (COM & LPT)" and see what you have there. You should have something in there which references a "USB Serial Port" (that's what mine says in Windows 7 for my PSR500). If you don't have any proper com ports showing, you may need the drivers to be reinstalled. Starrsoft has them on his page, if I recall correctly.
