Unitrunker Unitrunker locking up
phillydjdan
I've had this issue pop up on other computers and now my tablet is doing it. I can start Unitrunker and click the SYSTEMS tab but when I try to pull up a certain system is goes NOT RESPONDING and I have to manually end the task. It seems like the issue is limited to a system that has the DELEGATE field set to 7FFFF-FFF which I believe is the default. I cannot open or edit any systems with this delegation since running it today. There has to be a solution to this. And while I am on the subject of delegation, can anyone tell me how I can separate groups so that they only display on 1 system? What I mean is this: I monitor the control channel for at least 2 different systems that use TGs 1 through, say, 59, odd numbers. So when I am monitoring system A I see the TG aliases I setup, but then when I monitor system B I get the same TG aliases from system A, which I do not want. I want TG 1 on system A to have a separate alias from TG 1 on system B. Any help?
Unitrunker2
It sounds like you delegated two systems that are not actually related.
Delegate
You will need to un-do the delegation. Check the Archive tab for an older copy of your data. Use the "take me back" button to revert to that data.
As a last resort, hand-edit the Unitrunker.xml file to remove the delegation attribute from the affected system(s).
phillydjdan
Will I lose the data I collected over the weekend if I go back to an earlier point? If so I would rather manually edit the xml file. Not sure how to do that, however.
Unitrunker2
How much you loose depends on how far back you go.
phillydjdan
I found a closed thread that detailed editing the XML file. Looks like that worked. Everything looks good now
