UniTrunker: Multiple VCO's
N9JIG
Sheriff
Moderator
Far NW Valley
When I start Unitrunker using my RTL-SDR it shows 3 VCO's for it on the receiver page. I have to change this back to 1 VCO in order for the application to work properly.
Is there a way to have the application default to one for this device?
N9JIG
Sheriff
Moderator
Far NW Valley
Hi Rich;
Once you've configured your Realtek - it should stay that way.
When I stop the application and allow it to save the data and then restart it it does not save the VCO count nor the "RTL Device" settings ont he Receiver Page, I have to go back and change them each time the application restarts.
I am running 1.0.33.6 if it matters.
The next time you run the program ...
* click on the Archive tab.
* click the Folder tool button.
Windows Explorer should open on the directory where the program is trying to save your data.
You should see a file named Configure.xml and multiple files similarly named Unitrunker.xml, Unitrunker.xml.1, Unitrunker.xml.2 etc.
Make sure this folder is not a place that is normally write-protected like "Program Files", "Windows" or "System32".
