I've been noticing that as traffic occurs, every now and then a call or two don't highlight to indicate that it is opening the audio for that call or it will wait for a call to end before opening that frequency. Which is odd because it usually happens when unitrunker is only using 1 or 2 vco's out of 8 voice role vco's. It doesn't happen on the same frequency every time or the same SDR. Though it does seem to prefer a specific SDR over the others.
I have 5 SDR's with a voice and signal VCO for each frequency of the system.
So SDR 1 will have a voice and signal VCO parked (for a total of 4 vco's) on frequencies 855.81250 and 855.2250
SDR 2 will have voice and signal VCO's parked on 856.83750 and 856.22500 and so forth until all 8 frequencies are set among the 5 SDR's.
All VCO's are set to 0 squelch and have their own virtual audio cables feeding into a recorder.
One odd behavior I've also noticed is that unitrunker will tell a VCO to drive to a opened carrier instead of using the VCO already parked on that frequency.
The control channel shows 100 decoding almost all the time.
The goal is to be able to record all traffic from an 8 LCN system. I'm not opposed to adding 3 more SDR's to the system if needed and cut down the VCO's to one of each role but I'm not sure that is a cure.
Just for FYI, the system I am attempting to monitor is : https://www.radioreference.com/apps/db/?sid=1678
Unitrunker version is 1.0.33.6
Winblows 10, not opposed to putting it on Linux if it would help
i7-7700K processor 4.2GHZ/32 GB ram (and system resource monitor says I'm not taxing the system at all)
All SDR's are on a powered USB hub
I THINK this is the problem occurring in the log
Code:
Log file originally created as .\R00000007\Tuner-20170703.LOG Version: Unitrunker 1.0.33.6
Opening.
Setting Policies.
Gathering interfaces.
Found 1 associated interfaces.
USB::USB::ControlTransfer fails, 0000001F
Found R820T tuner
PLL LO 56000000 prescale 4 Quotient 31 SDM 7281 error 22.
gain 84 C4 FF E6
PLL LO 860101250 prescale 1 Quotient 59 SDM 47792 error 79.
gain 80 FB FF E6
gain 80 FB FF E6
gain 82 FB FF E6
gain 80 FB FF E6
gain 80 FB FF E6
gain 80 FB FF E6
gain 82 FB FF E6
gain 80 FB FF E6
gain 80 FB FF E6
gain 80 FB FF E6
