Unitrunker + pre-amp = help configuring, please
William
So here's my next question in my quest to get Unitrunker up and running.
I've finally got my pre-amp from CanaKit/Hobbytron that was recommended in another thread and now I'm trying to make sure I connect it correctly. It looks pretty straight forward, but I wanted to check with you experts...
From the tap on my radio I need to go into the mic input on the pre-amp, correct? This is simply a mini-phone to mini-phone connection as I see it.
Then from the pre-amp, I need to go into my computer, correct? The pre-amp has just two simple posts for me to connect to. I'm assuming I could get a simple piece of wire, attach a mini-plug on one end and then solder the other end to the two posts.
Obviously, I need to get a 9v battery to power the unit. Also, if I had good soldering skills, I know I could mount this inside my radio and power the pre-amp from there.
But for a basic, external connection, is it really this simple?
Are there any pitfalls I am missing? Tip polarity? Etc?
Thanks in advance for your help.
William
Hi William;
Yes.
Yes.
Yep.
The only concern is over-powering the computer's input. If you're using a pre-amp that shouldn't be a problem. If it has a volume control - start with the lowest setting and gradually increase until you've got a useable signal.
-rick
William
Thanks for the reply.
Hopefully I can do some work on this late this weekend.
William
