Unitrunker question - Multiple copies of a system
BM82557
Berkeley Co WV
What I would like to do is have 2 copies of the same system, one with my normal lockouts, priorities etc. and the other with all talkgroups with the exception of one range locked out. I could go through the current system and change all of the lockouts and then change them back afterwards but as the system has 250 talkgroups I am hoping that there is an easier way to do this. Can this be done?
Here's a simpler suggestion.
Don't install another copy of the program. There's no need.
Do create a shortcut. Set the path to the EXE under Program Files. Set the working folder to a different path of your choosing.
You'll have to decide which short-cut to use based on your needs.
BM82557
Berkeley Co WV
Thanks, this does what I need without a lot of hassle.
Yes. You can configure as many receivers as you want. In your case, that would be three. One signal receiver for NO. Add another signal receiver for Slidell; plus one voice receiver.
