Unitrunker Question
PVPD730
Is it possible to transfer Unitrunker logs from one computer to another? I've recently started using the program, with my laptop being used for primary logging. I would like to be able to transfer those logs to my desktop at some point. How would I accomplish that task?
thewraith2008
I have not tried this and I assume that the LOGs are stored where Unitrunker stores all the other stuff.
The Unitrunker path is in the 'Options' > Unitrunker
eg. Path: C:\Users\YOUR_PC_USERNAME\AppData\Roaming\Unitrunker
After installing Unitrunker on the laptop then
Copy all that folders contents (files and sub folders) to the laptop PC.
eg C:\Users\YOUR_LAPTOP_USERNAME\AppData\Roaming\Unitrunker
That should clone your setup from PC to Laptop.
Cheers
PVPD730
Cheers
That worked. Thanks!
