Summary of what's new:
* General
Missing graphics for readme file.
Peers tab - LCN not updated at first opportunity.
Persistent UI geometry - window placement information is stored for some windows. The next time the window is displayed - it will appear in its former location (to be further improved).
The "Running" drop-down box is now display only. Use the Start arrow or Stop box on the toolbar.
Start / stop race condition that could cause crash - fixed. This is a major change affecting all receiver models.
Replace critical sections with lock free mechanisms for better concurrency and speed.
Voice following - clearing the Listen option but voice receiver continued to get voice calls - fixed.
Restore volume and squelch for headless radios like Icom PCR series - fixed.
Removed volume control of Uniden DMA models - avoid fighting with user's manual volume setting - fixed.
Voice following of patched talkgroups - supergroup inherits listening properties of the subordinate groups.
* Detection
For discriminator signal receivers, the program will display the type of signal in the Protocol field. In addition to detecting 2 slot OpenSky and ProVoice, the program also detects DMR and NXDN. To be clear, these formats are *detected*, not decoded. If you find a control channel but can't figure out what it is, this feature may help.
* P25
P25 VHF decoding from discriminator audio - much improved.
P25 VHF decoding from inline receivers - bug fixes.
P25 TDMA bandplan fixes.
Inhibit radio events displayed.
Decoding health formula revised. Some VHF systems only produce 27 to 35 TSBKs per second. Compare to 40 TSBKs for 770/851 Mhz systems.
Faster error correction calculation.
* Motorola
Better bandplan selection for some smart zone systems.
935 Mhz bandplan had incorrect channel spacing value (work-around was to use the 935 Mhz plan in the Band Plan Wizard) - fixed.
* EDACS
Unit IDS erroneously formatted as AFS when Fleet display mode enabled - fixed.
Leading zero missing in AFS fleet digit - fixed.
* RR DB Download
Did you check "Remember Me" to save your RR DB password? The password is now stored in a separate file using the Microsoft crypto API (no more clear text passwords).
SHA256: 01a1e5a16981ea54e253e2599ba99fc161c6b472927e4e97e1ae52ffe16b71be
SHA1: 587d59b0badac52b7e46096dbe0330a40fa5742e
MD5: c1bf67deafbe0756679cdf56ad802d23
* General
* Detection
* P25
* Motorola
* EDACS
* RR DB Download
