Hi bigbud;
Does the device work with an SDR program like SDR#? Can you see a water fall display?
What tuner chip does your RTL stick have? Unitrunker only supports RTL sticks with the R820T chip. For other tuner chips like the E4000, you'll need to use a separate program to control the RTL stick and pipe discriminator audio in through VB cable or VAC.it always says 1 device found but is busy i have done everything reinstalled drivers I can't get it to work I just want to throw it in the trash
