Unitrunker Second Public Beta
mmcgee
Seattle WA
First Bug :(
Channel 1022 maps to a frequency of 0.0 (should be 868.95 - it's the control channel!). Channel 0 (851.0125) is suspicious - shouldn't be part of the system... Reception quality is 100%
jlh
Thanks Rick, appreciate your work.
Been running it for 10 minutes, looks good, I like the new view options.
Dewey
A-w-e-s-o-m-e ! ! !
Rick... your new release is AWESOME!!! I love the way that the associated colors are carried over to all of the various views. I have one question... you spoiled me with those
l-o-n-g label that were in v1. Do you think you can include an option to go back to the long labels in the next release?
Even if you can't.... THANKS for such a GREAT program!!!
Dewey
For channel 1022, check your band plan. Channel 1022 (3FE in hex) should be covered.
For channel 0 ... trying removing it ... then watch to see if it reappears. From the main menu select [F]ind -> [C]hannel and enter 1022 for "Find by LCN". When the channel info appears for editing, select the "Delete" menu option. If it reappears, you can turn on logging to determine from where the bogus channel came.
-rick
Joseph11
Finally! (I didn't get the second post in the topic, darn!) Downloading right now. Thanks.
rescue161
KE4FHH
Hubert, NC
I'm having a lot of problems trying to keep Group Labels. Every time I create a label, the next time that talk group becomes active, it creates a new talk group without a label and the one that I edited to have a label does not become active again.
On the old UniTrunker, I was able to modify frequencies, talk groups, etc and was able to view the changes as I made them. This one won't allow the changes to show until I exit the screen and go back to it.
I've tried to uninstall and reinstall, but that doesn't seem to help.
I went back to the old one for now. I think it was even better than the 1st public beta.
Airfire
Northern Virginia
I'm having the same problems trying to label groups and users as well. I even tried to modify the group file via a text editor and it would not recognize the changes.
It's tracking abiltiy and layout are outstanding! Thanks for your effotrs.
Jim
dfoutch
Anderson, Indiana,46013
rick: When a group is edited. it is rewritten with a 10 degit group number. The "user" file is ok.
dean
edit: I was wrong, the user file is also rewritten with 10 degits.
dean
ronenp
Few problems (bugs) ?
When Software startup in the first second untill it complatly decode the controll channell work it show 851.0125 as Red (control channel) and afterword it stay as Brown
looking at the view show ot as channel LCN 0 with this freq marked as control channel
and this is incorrect in matter of fact this channel is not in use at this site at all
2) trying to edit the group and entering a lable to it open new group and the old group cant edited ....
so far all other behave ok ...
Ronen
http://www.ronen.org
KC1UA
This ain't gettin us noplace, we'll have to blast!
Thanks Rick, and Happy New Year to all.
I have only tried this on one computer thus far (IBM Thinkpad 600E laptop). I'm finding I am unable to widen the display as I could with the first beta. Certainly not the end of the world but it would be nice if it could be stretched out.
I too experienced the 851.0125 "issue", as well as the group label issue. I'm not sure if this is a coincidence, but after I deleted this channel, SOME of my group ID's started working. However, it appears that the ones showing up are the ones that I added with the first beta.
When viewing groups, will there be/is there a way to select that group for direct editing? Same with users?
The affiliation view is great, as are the remaining views. As stated above, group and user ID's display on those views without issue.
Just restarted the program 851.0125 reappears immediately. When I try to delete it, it appears that the Delete option can't be selected the first time. I press the D key, but nothing happens. I escape, and then re-enter. Delete is available and actually highlighted.
I'm also seeing duplicate channels showing up. LCN 378 (860.4625) just did it this time, and the control channel LCN 369 (860.2375) did it the last time the program was running.
Nice job, and thanks for your great efforts.
rescue161
KE4FHH
Hubert, NC
Does the "affiliation" only work on Smartzone systems? It is not working on the systems here. They are all UHF single site systems.
I'm still getting the best results with version 0.1.0.10
