UniTrunker, Small issue
Syncopations
Hears voices in my head.
South Texas
So I'm using UniTrunker with my Pro 197 scanner. I'm successfully scanning a ProVoice system and seeing talk groups and radio IDs popup as I hear them on my radio. It shows all 5 frequencies in use...blah blah blah. It's working. However, every so often, my scanner automatically switches to the control channel and will not let me change it unless I close out UniTrunker.
Does anyone know why it would do that?
Syncopations
South Texas
Not quite. The scanner is scanning "Scan List 2" which is a ProVoice system. So I can't hear anything until it automatically switches to the control channel. Then I just hear the control channel noise. I hear the traffic using my Jaguar 700p radio which has ProVoice.
There are 5 frequencies and about 6 or 7 talk groups, all ProVoice on that system. I've programmed them all in to the Scan List.
D
DaveNF2G
Guest
In other words, yes you are "listening" with the scanner.
Unless you are tracking LTR-Regular, your data scanner should not be scanning. It should be sitting on the control channel.
Try this:
Remove the talkgroups from the scan list. Add a group ID you know is not used. Scan that. You dont want anything that might cause the radio to leave the control channel.
As a side note, check your firmware for updates. If you still have problems, I'll likely ask for a Tuner log file from your signal receiver.
