Unitrunker Source
Not sure if this is allowed here, but does anyone have the source code?
Just looking to change the scraping details setup from rr to a standalone offline csv.
Able to capture and swap traffic using packet/easyphp but would like to make a simple alteration to the program itself w/o creating a server.
Moderator edit: discussion involving non-public source code (i.e. for the scanner that was originally mentioned here) is not permitted. Post edited.
The source code has never been published in it's entirety. Some utilitarian portions are being made available (XML, SOAP and UI) related but not the complete program.
The program doesn't scrape HTML. It uses the RR SOAP interface to download individual systems.
If you can deal with XML, the program will support that. It can also import the old Trunker and Retro CSV formats.
Yes thanks I noticed that, I am creating a new program and will release a copy so you know what I mean in regards to the gui. Not going to use other progs original codes, just wanted to see what they did is all.
