Unitrunker Squelch Problem
ab8sf
Southwest Michigan
I recently downloaded Unitrunker 1.0.30.10. I have it installed and working on 2 laptops with DSD+. On the desktop use at home (better speakers) I cannot get the squelch to silence the analog stream. Our local system is mixed Provoice and analog so I would like to be able to maintain analog monitoring. The digital audio pipes to DSD+ OK, but the analog hiss is on top of and louder than the digital voice.
I am using Windows 7 with the on-board audio. The older Unitrunker + SDR# + DSD 1.60 worked OK on this box. Any thoughts?
MikeDingas
Warner Robins, GA
First a caveat. I've only been using SDR for a short time and only recently got it to work. So bear that in mind.
The background noise was absolutely distracting. What I ended up doing is turning the AF Gain to about 25% or just at the point where the hiss was barely noticable. This seems to have no affect on the voice strength. I'm using a single receiver, SDS, DSD 1.6.0, Unitrunker 1.0.30.10 and the small provided antenna.
