Unitrunker voice following
foxtail
Niagara Region Canada
Trying to get unitrunk to voice follow with second radio. Have pro2006 disc. tap as the signal and 396t as the follow. I can see the 396t move to the voice channel but no voices come from it. I think I have all the check marks it the right place. Want to test voice follow on sys id#3c08 T.O. system. Not sure what else needs to be done to get 396t to follow cc from pro2006. Pro2006 by itself decodes the info...just won't give voice over to 396t. Any help would be great, thanks for your time. Unitruker Ver.1.0.25.12. I know this can be done with just the 396t but would like to test voice output to second radio.
Test the radio with the Park frequency and mode. Use a known active conventional voice channel.
If that works, some things to check ...
1. are all voice frequencies correct?
2. BCD396T volume setting?
3. BCD396T squelch setting?
