Unitrunker w/ two Voice Reveivers
kb3lms
Here is a question from a new Unitrunker user. (What a great piece of software!) I have Unitrunker set up with one voice receiver as and RTL SDR# and a second as a Pro-2052. The SDR# receiver is connected to both DSDplus to decode digital and the Pro-2052 for the moment is just playing through it's own speaker. Everything works fine. However, I am monitoring a mixed Motorola system (about 80% analog) and on analog transmissions both voice receivers are tuned to the analog transmission, unless there is more than one at a time. Is there a way to stop this or is it a side effect of the SDR# Remote.dll setup? I'm running Unitrunker 1.0.26.16. I am aware of the newer version to control multiple RTL-SDRs but for some reason it has not worked on either Windows 7 PC I tried and 1.0.26.16 works like a champ.
My signal receiver is a tapped Pro-2037. Works great.
Our county will switch over to a P25 (Phase 2) system in May and I would like to be able to track it. Don't have $600 for a new scanner and Unitrunker works great anyway!
With one signal receiver and two voice receivers - the voice receivers should be following separate calls. What you describe should not be happening. I'll check this out.
kb3lms
@Unitrunker: Thank you for looking into it.
Our county (Berks, PA) will go to a P25 Phase 2 all digital system in May of this year. I am hoping DSD+ will decode the audio by that time. UT tracks the system perfectly right now but there is very little activity and only 1 TG. Our adjacent county is running a Motorola Smart Zone system that I monitored with my Pro-2052 until they rebanded last year. The same story with the nearby city of Reading, PA. UT will simultaneously track 2 of these systems without fail. Unfortunately the County police and Reading police are encrypted so not much luck there but I have some small sliver of hope that might change with some groups on the county system because it isn't going over well.
The Pro-2052 work perfectly with UT on the Motorola systems. The P25 system is 773 MHz so that will be dongles.
