UniTrunker
burchill
halifax
so, what is UniTrunker about and does it decode P25 encrypted transmissions? and how do you use UniTrunker?
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
In the US, it is illegal for a non-authorized entity to decrypt an encrypted transmission. Any encryption worth having would not be able to be broken by a program like this.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
UniTrunker is not really a programming package, although you can use the information gleaned from it to help program a scanner hearing an unknown trunk system - hopefully the mods will see this thread and move it.
However to answer your question our wiki once again comes to the rescue; you can read about the basics here...
UniTrunker - The RadioReference Wiki
and if you have further questions on decoding control channels (which is what UniTrunker does), please post them here...
Trunking Control Channel Decoding - The RadioReference.com Forums
best regards...Mike
K9WG
Greenfield, Indiana USA
UniTrunker decodes the control channel data and displays it in a readable format. It does not decode encrypted transmissions. To use UniTrunker you have to be able to either feed the control channel data from the receiver to your soundcard or get the data via the USB CC-dump feature avaliable on some receivers.
