Unitrunker
ansul1001
#1 Member
Hesperia California
Static after transmission when listening to a Motorola analog trunking system i am getting static after the person stops talking for like 3 seconds this never used to happen anyone know whats going on
natedawg1604
Colorado
Can you post a screenshot of your setup (so we can see the RSSI values)? It's possible you have reception issues and should try moving your antennas around. You could also increase the squelch on your voice receiver.
natedawg1604
Colorado
Hmm, a RSSI value of 52 suggests weak reception, so you should definitely move your voice antenna around and try to get that RSSI value closer to 60. You could also try increasing that squelch setting to reduce noise/static between calls.
KD8DVR
Columbus, Ohio
That Window reading is also too high. The dongle is off frequency. The ppm setting needs fixed and the auto correct needs on. My dongles hate a window over 100. Gotta be 50 or less....but then I listen to digital.
Sent from my LG-D631 using Tapatalk
