To anyone looking to acquire commercial radio programming software:
It is for the XG100P, it did seem to fix some bugs such as the scan nuisance delete side button. R2A26 is the latest stable version from TAC. I just loaded the radio so will have to see what else if any is different.
Checked online. XGP2A26 was released 3/5/14 as Rev B to 14221-110-8140. Release notes have not been posted yet and show as ""Currently Unavailable Rev B"
It is for XG25P, M5300,7200,7300, P5400,7200,7300,5500, XG75P, XG100M,XG100P CH100
The Unity without DTMF is still a great radio, however as an owner of all three I rate the APX hands down as the king, then the Unity and Liberty. They all have their quirks.
4.1 R-STATE R10B
Support has been added for XGP R3 features, including the following:
• Channel Entry for Unity XG-100P – “Select Channel/Group Number” has
been added to the shortcut menu options.
• DTMF – support has been added for XG-100P.
• A/B/C Switch for Unity XG-100P – “Three Position Switch” options
have been added under Programmable Knobs settings.
• Talk Around Indication” has been added to Conventional and P25
Conventional Systems. The selections are Disabled, Transmit Only, or
Transmit & Receive. These controls apply to Unity XG-100P and Unity
XG-100M.
Also looks like they dropped a new ref of XGP2 (rev C) this one with release notes
Ok - The latest firmware for the XG-100P that activates the DTMF pad is XGPR03A09. The DTMF pad does work, but you have to have RPM 10B07 or better to activate it in the programming.
"gesucks" mentioned the "Talk Around Indication". It is a cool feature, but there are limitations. If the channel has ANY type of signalling (Type 99 paging, MDC, etc) this feature WILL NOT WORK.
Again, another Harris failure. Something we have all come to accept as routine...
I have to be honest, I really don't see the need for the talkaround indicator. Using both the 100p and 100m with CH-100 head there are so many systems and groups available and the alpha tags are long enough that it just really isn't something that I see the need for. The same goes for DTMF encode from the keypad. In the public safety LMR world, it isn't something that I have every had the need for.
