Unity XG100 - not working on P25
19sargeusmc56
Is there any way that anyone might know of to troubleshoot why this radio doesn't work on P25?
gdsteele
Is P25 enabled on your radio? If you look under <Menu> <Utility> <Feature Info> It will say P25 CONVENTIONAL if it is enabled. If not, I don't think it will work on P25.
prcguy
Did you make a conventional set or a P25 conventional set? Is P25 selected in the set? Do you have the right NAC? Not sure how this affects things but do you have C4FM selected? Other options are narrow and wide but I don't know of that will program with P25 selected.
BigLebowski
Piedmont NC
Okay.. you need to be more specific about what is not working and what you are trying to do if you expect anyone to be able to help you. Also post the firmware and features your radio has enabled.
K2NEC
This ^^^
We don't read minds
Also, XG100P or XG100M?
19sargeusmc56
This portable radio has current firmware, programmed with a mission plan setup with viable P25 phase 1 info using the current version of RPM. The radio is equipped with the P25 feature. This personality is operational in a similar radio. I'm thinking there's some sort of failure and I was soliciting any troubleshooting info along those lines.
........and can I say.....respectfully....Holyshizit! NOBODY SUGGESTED YOU ALL ARE MINDREADERS! Wow.....
prcguy
The XG-100P is a very complex radio, not to mention the RPM. Out of the gate there is a big list of potential things that could be the problem and the more info you give the smaller the list gets and the faster you can fix it.
K2NEC
We arent trying to hassle you or be a pain, but you have to see it from our point of view. You want us to help you with a radio problem but you give us 1 sentence to work with and you give no information on the radio, what you are trying to monitor, or what your current settings are, etc.
