I have a wideband XG-100P and it doesn't have 50 or 58, so 50 probably allows some limited WB capability.
Oh… so you have a clone plan loaded currently. From the mission plans page, push the right arrow and you will move to the clone plans tab. I’ve never used a clone plan so I’m not sure what the available options are, but I don’t think you can extract those… bummer.
A corrupt mission plan doesn’t ruin the radio (I suppose it’s possible, but extremely unlikely), but may necessitate a three finger reset, which would just remove all mission plans and reset the radio to factory, leaving the firmware at whatever version it is currently.
Extracting, modifying, loading over and over can just make the mission plan unstable, which may cause the radio to randomly reboot or freeze up, but I’ve never had this happen (I don’t extract except for the one time when I received the radio just to back up existing data).
50 is OMAP Wideband Disable, which is different that 58 Wideband Disable and I think stillallows you to program Wideband ham frequencies, but I’m not positive about that. I’ve never had a Harris with feature 50. Maybe someone else can chime in on this.
All XG100P radios support multiple mission plans, I just didn’t know that’s the radio you had and not all Harris radios support multiple mission plans, some use a fixed personality.
Good luck!
-B
