Universal Scanner Audio Player
deim
Universal Scanner Audio Player developer
Saint Petersburg, Russia
Hi guys!
Sorry to keep you waiting updates.
if I remember correctly, i need to fix these points:
1. SDS200 Motorola DMR system in Conventional Mode USAP doesn't display tgid.
2. Return separate volume control for different audio types.
Need to fix other bugs or any suggestions for improvement?
bravo14
Polk County FL
Once awhile I'll get a error when playing audio I have to close the program (it freezes up) not sure what causes it. Using Ver 2.0.10
deim
Universal Scanner Audio player 3.0.5
Changes:
Added separate volume ratio for Uniden, Whistler, Icom, Aor audio files.
Added code(NAC, CTCSS, DCS) parsing for HomePatrol wav files.
Fixed TGID parsing for SDS100/SDS200 scanners.
Fixed UID parsing for SDS100/SDS200 scanners.
Fixed Site parsing for SDS100/SDS200 scanners.
b52hbuff
Hi guys!
All of my concerns are in the thread. The last two are here:
deim
Hi! This points already fixed in USAP 3.0.5. Can you check it on your files?
WX4JCW
Stow, Ohio
what would really be cool would be the ability to read the unication audio backups if this has not been previously mentioned
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
While we're on that topic, I would like to see DSD+ per-call files supported. They play back fine now, but the metadata (if any) is not imported; some fields get populated with data based on the filename. The tricky part is you can choose in DSD+ whether or not to include certain elements of the details (IIRC, talkgroup ID, radio ID, possibly time/date) of a recording in the filename, so it would be tricky to cover them all.
If you're up to the challenge, I will try to save some of my recordings in the future, try to capture as many different circumstances as I can, and share them with you.
deim
I PM'd you a dropbox link
I think it is possible to add this type of audio files with text description in USAP supported files.
To do this i need more files with different transmission types. private calls, encrypted, high priority and etc.
deim
Yes, I am ready to fix this)))) Send me recorded files with full description and I'll try to fix this asap.
