PMJ2kx
There's a system being built - guessing off of Bald Peak - in the area that may be a federal system, because none of the 700Mhz frequencies come up in the ULS, nor in the Region 35 plan. I haven't had any activity on it until today, when they were doing voice and radio testing, some of the comms being TDMA.
The system itself has been around since at least April of this year. Here's the info I have so far:
Code:
FileVersion:7
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 00A
System Name :
WACN : 9254A
Tower Number (Decimal): 101
Tower Number (Hex) : T0101
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Fri Aug 15 12:35:27 2014
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,769.00000,0.00625,30.00000,"Confirmed",0.00625,1
08,769.00000,0.00625,30.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0012","",769.07500,"00-0012",799.07500,0,0
"00-0044","c",769.27500,"00-0044",799.27500,0,0
"00-0107","avd",769.66875,"00-0107",799.66875,0,79
"00-0228","",770.42500,"00-0228",800.42500,0,0
"00-0312","",770.95000,"00-0312",800.95000,0,0
"00-0389","a",771.43125,"00-0389",801.43125,0,0
"00-0467","a",771.91875,"00-0467",801.91875,0,0
"00-0553","a",772.45625,"00-0553",802.45625,0,0
"00-0665","a",773.15625,"00-0665",803.15625,0,0
"00-0729","c",773.55625,"00-0729",803.55625,0,0
"00-0834","",774.21250,"00-0834",804.21250,0,0
"08-0214","v",769.66875/0,"08-0214",799.66875/0,0,24
Code:
FileVersion:6
# Talkgroup List for this system
# Format: Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits
# Priority Values: 0=Ignore, 1=Highest priority, 99= Lowest Priority
2,50,"T: 101 DT: 8/15/14@11:58",1408130427,"08/15/2014 @ 12:20",1408129089,"08/15/2014 @ 11:58","#000000","#000000","N",103
Code:
FileVersion:4
# Radio List for this system
# Format: RadioID(Decimal),Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),Text Color,BG Color
9980002,"TG: 2 DT: 8/15/14@12:20",1408130488,"08/15/2014 @ 12:21","#000000","#000000"
9980003,"TG: 2 DT: 8/15/14@11:58",1408129818,"08/15/2014 @ 12:10","#000000","#000000"
9980005,"TG: 2 DT: 8/15/14@12:03",1408129872,"08/15/2014 @ 12:11","#000000","#000000"
9980009,"TG: 2 DT: 8/15/14@11:58",1408129836,"08/15/2014 @ 12:10","#000000","#000000"
