Unk 700Mhz System SW of Portland
PMJ2kx
Utah County, Utah
There's a system being built - guessing off of Bald Peak - in the area that may be a federal system, because none of the 700Mhz frequencies come up in the ULS, nor in the Region 35 plan. I haven't had any activity on it until today, when they were doing voice and radio testing, some of the comms being TDMA.
The system itself has been around since at least April of this year. Here's the info I have so far:
Code:
 FileVersion:7
-TowerInfo
#This section is here for information only.  With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID             : 00A
System Name           :
WACN                  : 9254A
Tower Number (Decimal): 101
Tower Number (Hex)    : T0101
Tower Description     : (null)
Control Capabilities  : Data,Voice,Registration
Call Sign(s)          :
Timestamp             : Fri Aug 15 12:35:27 2014
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,769.00000,0.00625,30.00000,"Confirmed",0.00625,1
08,769.00000,0.00625,30.00000,"Confirmed",0.01250,2
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-0012","",769.07500,"00-0012",799.07500,0,0
"00-0044","c",769.27500,"00-0044",799.27500,0,0
"00-0107","avd",769.66875,"00-0107",799.66875,0,79
"00-0228","",770.42500,"00-0228",800.42500,0,0
"00-0312","",770.95000,"00-0312",800.95000,0,0
"00-0389","a",771.43125,"00-0389",801.43125,0,0
"00-0467","a",771.91875,"00-0467",801.91875,0,0
"00-0553","a",772.45625,"00-0553",802.45625,0,0
"00-0665","a",773.15625,"00-0665",803.15625,0,0
"00-0729","c",773.55625,"00-0729",803.55625,0,0
"00-0834","",774.21250,"00-0834",804.21250,0,0
"08-0214","v",769.66875/0,"08-0214",799.66875/0,0,24
Code:
FileVersion:6
# Talkgroup List for this system
# Format:  Talkgroup,Priority,Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),FirstSeen(Unix),FirstSeen(Human),FG Color,BG Color,EncSeen,Hits
# Priority Values:  0=Ignore, 1=Highest priority, 99= Lowest Priority
2,50,"T: 101 DT: 8/15/14@11:58",1408130427,"08/15/2014 @ 12:20",1408129089,"08/15/2014 @ 11:58","#000000","#000000","N",103
Code:
FileVersion:4
# Radio List for this system
# Format:  RadioID(Decimal),Description,Lastseen(Unix),LastSeen(Human m/dd/yyyy),Text Color,BG Color
9980002,"TG: 2 DT: 8/15/14@12:20",1408130488,"08/15/2014 @ 12:21","#000000","#000000"
9980003,"TG: 2 DT: 8/15/14@11:58",1408129818,"08/15/2014 @ 12:10","#000000","#000000"
9980005,"TG: 2 DT: 8/15/14@12:03",1408129872,"08/15/2014 @ 12:11","#000000","#000000"
9980009,"TG: 2 DT: 8/15/14@11:58",1408129836,"08/15/2014 @ 12:10","#000000","#000000"
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
I have a strong suspicion this might be part of OWIN. They might be testing a site, allowing the transmitters burn-in.
73's
Ron
Thunderknight
Bletchley Park
At least some of those frequencies, such as 769.66875, are state license block frequencies. Those do not require site specific licenses, as each state has a block license for the state channels.
And IIRC, Feds can not hold a license (or its equivalent) in 700 narrowband.
PMJ2kx
Utah County, Utah
I stand corrected - just read the paperwork in the last buildout update, and sure enough, this is indeed part of the trunked portion of the state radio project.
This is the Chehalem Site.
ChrisP
Portland, OR
I was just in Salem today and spotted this site there:
FileVersion:7
-TowerInfo
System ID : 00A
System Name : OSRP TRS
WACN : 9254A
Tower Number (Decimal): 3-3
Tower Number (Hex) : T0303
Tower Description : SALEM AREA 700 MHZ
Call Sign(s) :
Timestamp : Fri Aug 15 11:55:37 2014
-Tables
-Frequencies
"00-0075","a",769.46875,"00-0075",799.46875,0,0
"00-0147","a",769.91875,"00-0147",799.91875,0,0
"00-0267","a",770.66875,"00-0267",800.66875,0,0
"00-0313","a",770.95625,"00-0313",800.95625,0,0
"00-0405","a",771.53125,"00-0405",771.53125,1,0
"00-0685","c",773.28125,"00-0685",773.28125,1,0
"00-0725","a",773.53125,"00-0725",773.53125,1,0
Apparently Harris must use "00A" as their default system ID. I keep running into new trunked systems in all different areas that have no connection with each other, but are showing the same system ID, 00A.
- Chris
OregonScanner
In the July progress report it says that 6 of the 41 sites have been installed.
PMJ2kx
Utah County, Utah
FileVersion:7
-TowerInfo
System ID : 00A
WACN : 9254A
Call Sign(s) :
That's the Eagle Crest site just west of Salem.
