My PRO-2006 only gets occasional use, and for short periods of time. Yesterday, I powered up the scanner and the following occurred: The backlight was on, but there was no sound even with the squelch open; the LCD display was completely blank with no frequency, channel, or bank information; and the keypad did not respond to any key presses and didn't produce an audible beep. I pressed the "restart" button in the rear without any effect. The only work I've ever done on this scanner is to replace the EL backlight panel. Before this, the scanner operated without any problems. So, before I take it apart to check for any obvious problems, does anyone have any ideas of what I should be looking for?
