MttM1250
I have Police, Fire, and EMS programmed onto my two HT 1250's. After most transmissions on those frequencies, there is this unknown sound that plays. I also have MURS frequencies programmed onto the radios, and after transmitting on them, that sound doesn't happen. I don't have this issue on my XTS 5000, which is also programmed to the same frequencies.
Is there something in CPS that I can do to make this stop happening?
Sound: My Movie.m4a
Binger511
Pittsburgh, PA
Sounds to me like its just a squelch tail, which would be due to the absence of ctcss tones (67.0, 103.5, etc.) programmed to the desired channel. You probably have tones enabled on your MURS frequencies without you realizing. You can find what tones they are using, on the database or wherever you got your frequency information.
ff026
ff026
It’s a non standard reverse burst on the repeater you are listening to. Probably simulcast. In the CPS there is a setting for a check box “non standard reverse burst”. Check that box and try that.
K2NEC
Are you talking about the slight high pitched chirp at the end of the transmissions?
MttM1250
Thank you. This solved the problem.
