Unknown TG
KOK5CY
Mannford
I happen to be sitting next to my scanner and I didn’t catch the TG but I heard Barnsdall 1 calling skiatook pd for a radio check. But I was not quick enough to see the TG . Usually Barnsdall uses only VHF but I’m guessing that they jumped on the okwin because the nearest site to them is hominy.
I’ll be monitoring this a bit more closely.
ScanRafael
San Rafael, California
What system are you referring to?
You don’t say what scanner you’re using, but if it’s one of Uniden’s BCD of SDS series, its trunking discovery and replay/record features could be useful to you.
Freqed
I'm just a listener
Broken Arrow
Yes BCD Series, you need to test the replay button to make sure it is set-up correctly. If it is not set-up correctly, it will display that and you will have to turn it on and set a time limit of the recording.
