Unmonitorable construction
jasoyeom
Norfolk County
A paving company is paving the street in front of where I work. They use walkie talkies for traffic control, but my Close Call didn't pick them up. I was very close to the one person directing traffic and watched her talk on the radio. I presume it's one of those radios that use multi-frequencies and is not monitorable by scanners.
IdleMonitor
The Ottawa Valley - Eastern Ontario
Depends on what they're using. Generally speaking, they wouldn't be using anything too high tech like encryption or frequency hopping technology.
You probably just didn't find them yet. They're likely just using a VHF or UHF simplex frequency or FRS frequencies.
Do a TAFL search for the company and see if anything comes up for them.
A paving company is paving the street in front of where I work. They use walkie talkies for traffic control but my Close Call didn't pick them up. I was very close to the one person directing traffic and watched her talk on the radio. I presume it's one of those radios that use multi-frequencies and is not monitorable by scanners.
I don't know about Canada, but in the US most are using FRS radios or simplex nationwide freq's (I do traffic control and they'd NEVER give us a decent radio) most comms are short. Last car - Blue Chevy, send your traffic, all stop, etc.
mmisk
Ottawa Canada
If they are using a DMR system, I have found that Close Call will not lock onto a radio transmitting DMR, as its output is not a continuous carrier like a FM transmission.
jasoyeom
Norfolk County
I did monitor them for a bit and the one person was talking for more than a few seconds. She had a unit that had a corded microphone that she talked into. I don't know the name of the paving company as their vehicles only have a large green and blue 'G' on it. Perhaps scanning UHF would find them. Not sure.
gary123
Most probably UHF, most often FRS. Possibly DMR, thats why Close Call didn't grab them. When these situations occur, always try to get a look at the radio. It wont tell you the freq, but the antenna will indicate the band in use and often the radio description will tell you if its FRS or not.
Recently there has been a pile of users buying Baofang's or other super cheap radios. They could be on any default freq that it came with.
EJB
Downtown Hamilton
I live around 50 yards from a massive construction job here in downtown Hamilton. I Close Called them. They use 451.1875, it's a very common construction frequency.
hypersight
Canada
As others have stated, check the FRS channels.
Also you can try plugging in some of these frequencies in your scanner. They are common low power channels. Some are used in repeaters as well.
151.055
151.070
151.085
151.100
151.115
151.580
154.570
167.730
170.940
172.290
172.470
172.500
172.590
172.920
172.950
172.980
408.0125
451.1875
451.6625
451.7875
452.5375
452.8125
453.450
453.700
453.725
454.200
454.225
456.1875
456.6625
456.7875
457.5375
457.8125
458.700
458.725
459.200
459.225
460.925
465.925
469.2625
gary123
Nice update link for the default freq. I think Ill add them into my 536 files as a separate conventional personality.
emercer
That is highly unlikely, besides, the OP stated they were using radios and with speaker mics.
More than likely a company simplex frequency.
You can get network radios that run apps like Zello and speaker mics are optional.
IdleMonitor
Again..coming from someone that's worked traffic control for a construction company before. It's unlikely it's a highly sophisticated radio system.
Construction companies don't often spend lots of money on radios for traffic control.
Either they're a company frequency that's probably a VHF or UHF simplex frequency or a rental radio, or FRS. I've used both. I stand by my comment that it's unlikely to be Zello, frequency hopping or DTR type radios.
VE2NCG
Montreal, Qc
In Canada, radios rentals in simplex use 453-454, 458-459, 464-465 & 469-470, a simple search on thoses 4 segments and you will find your user, 458 & 469 are your best bets!
