danesgs
Everything on the radio works (for awhile, like 2 minutes) cold. Then you loose a signal until you power off and power it back on. The PLL cuircuit is fine I guess, I can tune around such as NOAA and let it sit there then in 2 minutes the signal is just static. What is throwing me is if its caps going bad turning it off/on should not bring the signal back but it does. Again for a short period of time. Any ideas? IF its a "witches hat" solder connection, running hot would cause a connection to go bad, but simply turning it off in that that should not cause the signal to return.
Anyone seen this before and can tell me where to look?
