Unwanted Weather reports
Rawkee1
Massachusetts
I have a BCD 996P2 and a Radio Shack Pro 2067. Lately, sometimes when I get a transmission broadcast on UHF, the pro2067 will start broadcasting a channel on the NOAA weather channel that’s not programmed on it. When the UHF transmission ends, the weather broadcast ends. How can I fix this interference? This does not happen all the time.
GTR8000
NY/NJ Database Guy
BEE00
You can try enabling attenuation on the offending channel, but there's probably not much you'll be able to do about it if you live near a strong NWR transmitter. Those GRE scanners had lousy front ends, which is why a strong nearby VHF signal can bleed through even on UHF.
MDScanFan
USA
That is an intermodulation product. A couple strong signals are received by your scanner at the same time. Within the scanner the signals mix and produce a signal at a different frequency (the UHF channel you are hearing the issue). The NOAA broadcast is a constant signal. Some other intermittent strong signal is being received that is mixing with the constant NOAA signal and resulting in the intermittent signals you are hearing. There is some basic math you can perform to figure out what the likely frequency of the offending signal.
A 162 MHz notch filter on the NOAA signal would likely remedy the issue.
AM909
Radio/computer geek
SoCal
@Rawkee1 : Here's a map of the relevant transmitters. If you click on the callsigns in the Station Listing, you get a better picture of where the site is. They used to include the power levels, but don't any more. In the NTIA file, though, they are mostly co-ordinated for 100, 300, or 1000 watts. In MA:
KEC731000414228N, 0703352W
KHB35500421244N, 0710652W
WNG574300423730N, 0703842W
WWF48125423812N, 0731000W
WXL93500421814N, 0715351W
WXM68300424153N, 0723618W
WXM82300420947N, 0732825W
E.g.: assuming they constructed the NTIA-coordinated power level (not a given), if you're anywhere near KEC73 at Camp Edwards, you'll have your work cut out for you. ;)
Rawkee1
Massachusetts
Separate antennas. The radio that’s blurting out the NOAA station is the Radio Shack Pro 2067. Not always, but when I get a UHF transmission on the BCD 996p2 at 472 Mhz, the 2067 sings the weather. Not all the time tho. The radios are about 2’ apart.
AM909
Radio/computer geek
SoCal
On what frequency is the 2067 hearing the weather broadcast?
AM909
Radio/computer geek
SoCal
Something like 472.5 - 162.5 - 150.5 = 159.5 is theoretically possible, though I don't think I ever found a 3-component mix like that. Might just be because it's so hard to track down. Does the weather transmission sound normal or is it really loud (like 2 or 3 times the deviation it should be)?
wtp
Port Charlotte FL
i have taken the frequency out of my radio, but.
i have a 396T and an XT.
when the XT had someone talking on our old 800Mhz system the T would get a 'birdie' on a 260 or 270 frequency.
it would not do it while scanning only during a conversation.
our county has gone to a 700 system and i have not found anything yet.
so it might have something to do with the I.F. so you might have to stat doing some math.
if i recall it might have been my pro92 that got the 800 band and cell phones.
the math was like 800 freq divided by 2 and add 16.05 3/4 of double the IF of that radio)
so 888.0 would be heard on 444+16.05=460.05 and i had to be fairly close to a transmitter.
Ubbe
Stockholm, Sweden
A transmitter close by are too strong for the receiver and it overloads. That's probably the reason why you have such problems finding a suitable roof antenna as a too good one will just exaggerate the problem and a lower gain antenna will perform better, but you really should notch out that offending transmitter frequency to solve the problem and increase your coverage range.
/Ubbe
Rawkee1
Massachusetts
When 472.3125 comes over the 996p2, the 2067 receives 162.40. The transmission of the weather station isn’t nearly as clear or load as if I tuned into that weather on its own. It’s also happens intermittently, not all the time. It’s a strange situation.
Ubbe
Stockholm, Sweden
It takes a spectrum view over the frequencies, perhaps a simple SDR dongle, and some time to find which frequency that are active every time you see the overload issue.
/Ubbe
