Upcoming trip to Gatlinburg, Pidgeon Forge questions
murrayustud
KI4DCR
raleigh,nc
Planning on a trip to Sevier County this Sunday & checking the database I see it appears that most everything is still on VHF/UHF? Is this correct? Any local monitoring tips would be appreciated, I'm using a Uniden 996XT & Pro-96
Thanks!
Charles
KI4DCR
jfhtm350
New Market TN
Pigeon Forge Police is (was) on the digital trunking system and can be picked up. Darn near everyone else has went to digital you cannot pick up. Dont remember which digital. From time to time they use the other frequencies you can pick up.
jfhtm350
New Market TN
Pigeon Forge PD is p25 digital trunked, but they more or less stay on the same frequency since they are the only ones on the system.
n4yek
Newport, Tennessee
Sevierville Police, Sheriff, Gatlinburg Police and Fire, Pigeon Forge Fire are Nexedge.
As jim has stated Pigeon Forge Police are P25 trunked, most county volunteer fire departments are on the Land Air LTR trunk system, Pitman Center and Seymour Fire still use conventional freqs.
The Smoky Mtn National Park communications are P25 with some encryption.
Any more, a scanner is pretty quiet while monitoring in the county. So much I wish for older times when scanning in the area was nice.
trumpetman
Charlotte, NC
Sevier County has one of the most diverse communications systems I've ever seen (and I don't mean that in a good way). I hate they went to Nexedge, they used to be enjoyable to listen to when I spent the weekend out there.
Props to Pigeon Forge for moving to 700 P25 at least, even if it seems like over-doing it. That will mesh nicely with the statewide system.
