UPDATE - 5/22/17
WhistlerWendy
Northwest Arkansas
HAPPY SCANNING!
The update will be available via the PC app after 6pm Eastern Time today.
The update will be available on www.whistlergroup.com after 8pm Eastern time tonight.
Instructions:
Update the PC APP
Update the CPU
Update the DSP
PC APP Release notes
* Redesigned the advanced options tab to include sub-tabs to allow the addition of new options.
* Added edit options for the RSSI received signal bars to the advanced options tab under the Display Options sub-tab.
* Added Load Defaults button on the DSP settings on the Receive/PCIF Options sub-tab.
* Added Options to allow modification to the ZeroMatic values for the scanner, including a Load Defaults button on the Receive/PCIF Options sub-tab.
* Added Australian band plan.
* When copying between the computer and the SD card, the default Delete flag will now be set to No.
* Corrected an issue when creating a new conventional channel using a CTCSS or DCS squelch value, the stored value would be saved incorrectly.
* Changed the Zeromatic code to verify and correct all values if they are found to be outside of allowed ranges
* Fixed a bug when attempting to load a list of trunked systems for import. This only occurred in some areas and under extreme circumstances.
* Corrected an issue where the trunking tables on Motorola VHF and UHF systems were not being set correctly when imported using the preferred method.
* Added option to the file menu to import the configuration from a WS-1040/WS-1065 or compatible scanner. This function will only download from the source scanner's working memory. It will not download from a V-Scanner folder directly.
* Updated the Save Configuration to Archive option to honor the -d command line switch.
CPU Release notes
* Added "Freq" item to Tune settings menu
* Filtered out Fn+<digit> combinations from scan list toggling
* NXDN: PROP_FORM message handling in conventional
* Added handling for certain multi-block PDUs (for some VHF systems)
* Fixed problem entering Skywarn mode when no scan lists are enabled
DSP release notes
* minor enhancements to P25 PDU handling
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Assuming this was applicable to the 1098 it's a fail for the CPU and DSP update, but the PC App was successful.
MichaelBhere
I read someone post last year with the same issue and recall he ended up checking for the updates individually and the updates were available. I do not have a 1098 so I cannot confirm if that will get around your issue or not but my TRX-1 updated without issues.
kh6sz
Gulfport, Ms
PC App updated properly.
CPU and DSP show no update available
TRX-1
P.S. Also tried them individually, no joy!
MichaelBhere
TRX-1
You may want to try again.
My TRX-1 now is using the following
PC App is now 3.5
CPU is now 5.4
DSP is now 3.1
K9DAK
Wauconda, IL
Wow, this sure would have saved me a bunch of time a year ago when I got my 1088! Imported flawlessly from my PRO-106, except the trunked systems came in as Canada; easy fix.
seth21w
Somewhere monitoring the air.
HAPPY SCANNING!
DSP release notes
Will this by chance help improve the robotic sounds I'm getting on a lsm system with my new ws1098?
BrianLoch
PA-US
I have not competed the update as of yet. However, I wish to Thank Whistler! I apologize for being mad at you.
davedecember
Update =Smooth as glass
Updated all,TRX-1 smooth as glass.Thanks Wendy and kudo's to the Whistler team.
Updated fine and works good...HOWEVER, every time I connect my TRX-1 and open the EZ-Scan it upgrades the firmware again, it's done it 3 times now.
Any ideas on how to prevent that?
Machria
Long Island, NY
TRX1 worked like a charm for me. THANKS WHISTLER!!! Nice work!
I hope we get an update of EZscan that gives us better working Import/Export features...... Copy Paste.....
BrianG61UK
England
For now you could turn off automatic checking for updates.
daddyjohn
I was able to update the software just fine and it restarted just fine. But now whenever I try to check for any updates, all together or individually, I get a "connection time out error". I have also gone to Whistlers website to try to download the updates individually but my webpage locks up whenever I try to log in to their website. I thought last night it was due to heavy user traffic but it is still the same this morning. Bummer.
dsankir
Waltham,MA
Looks like a connection problem between radio and pc.As i know there s setting option on windows,calculate time on usb ports.
