WhistlerWendy
Happy Whistler Wednesday!
Updates for the DSP, PC App and CPU have just gone live. The files will be added to the Whistler website shortly.
DSP Update –
• Fix issue with occasional audio drop outs.
PC App Update –
• Fixed an issue where the squelch value was not being enabled when adding a conventional channel unless the squelch type was dropped down first.
• Fixed issue where Provoice mode talkgroups on EDACS systems could not be selected or imported. While the radio cannot decode Provoice voice internally, it is possible to use the discriminator output feature of the scanner to decode the voice with a third party software application.• Updated the warning message when importing a system from the library that has no talkgroups defined. Systems of this type need to have the Wildcard option(s) turned on in the Import Options Screen to be monitored.
• When importing a system with no defined talkgroups, a wildcard talkgroup object will be created during the import, regardless of the wildcard settings on the import options screen.
• Fixed a sorting issue on the squelch column in the conventional tab.
• Fixed an issue with copying audio files when the alpha tag of a channel is a reserved file name (i.e. PRN, AUX, COM1 through COM255). The alpha tag will now have an underscore appended to the end of the name in this scenario.
• (TRX models) Include option to "Skip DMR TGID" when creating or editing a Conventional DMR frequency
CPU Update –
DSP Update –
PC App Update –
CPU Update –
