chris451rr
The FCC database and some listening while located in Dubuque county Iowa reveal that Edacs is not in use and the SARA system is in use,
I confirmed P25P1/P2 heard on some Sara Talk channels that are common with Linn/Johnson/Blackhawk county.
The database shows just the EDACS channels. I loaded everything possible into a TRX-1 scanner, and I also load just the raw talk channels in a 'notrunk' group
since there are times the control channel does not work but the talk channels do (under marginal conditions)
Not sure if there is someone in DBQ region that can listen with a trunking radio and collect the talk groups and control channels I did not do that while there.
One of the sites in this new P25 system is on the Wisconsin side of the Mississippi river Grant County (very high ground with great coverage of the city of Dubuque.
Reading Dubuque County E911 board it looks like they have Racom doing the installs etc but on the P25 system, and the Edacs phase out is possibly completed as that was not detected.
Reading the FCC database and comparing to the RR database, they have all the channels they need and about 5 sites.
It appears in the FCC DB but not as yet in the RR database.
