Update now sds200 dont work
MasterPo
NY
Hi all I did the update now it dose not owrk it looks like its scanning but not stopping on any thing have the sds100 running no problem is there a setting im missing??
thanks in advance
Bill
MasterPo
NY
ok checked radio it seem update did not work so I tryed again and got error. firmware checksum failure on SD card, so should i format the card and can i do that thru sentineil
a417
firmware checksum failure is Not Good™.
Format the card, replace if it continues to give you issues.
MasterPo
NY
ok now i get a quick error. sub cpu error is that the radio death??
Bill
n1chu
Farmington, Connecticut
No. I do t believe you can brick the scanner in that manner. Try the full update again… or do that clone thing I mentioned. If the SD Card works in the SDS100 it should work in the SDS200. Try taking the card out of the good scanner and using it in the errant scanner.
MasterPo
NY
ok uniden says it the main board so I have to send it in, still under warranty so just have to wait...thanks all
werinshades
Chicago , IL
Bill
Do not turn unplug the scanner when you see Firmware Update Complete. The CPU update comes next, then the Favorite Lists are downloaded then unplug.
Go to Scanner...Clear User Data...check the box to Display all Drives, then repeat the update and don't unplug like I posted above.
MasterPo
NY
I notice when the favorite list loaded there was a big delay at the end of it
pbuch
Claremont, CA
Hi All:
Getting the same Firmware Checksum Error on SD card on my SDS100 with the results described above. Scanner basically non-functioning. Tried the above suggestions already. Help!
MasterPo
NY
Hi All:
Getting the same Firmware Checksum error on y SDS100 with the results described above. Scanner basically non-functioning. Tried the above suggestions already. Help!
I had to send the unit in for repair they say the Checksum error is the main board, mine was still under warranty for the SDS200 so have to wait for repair or new one lets see what happens
pbuch
Claremont, CA
Seems weird that the same problem effects to 100 and 200. Lets see if #JoeBearcat has an answer.
pb
