TRX-2: Update Order
Mitch618
South Carolina
I'm getting a TRX-2 and I want to be sure I get everything updated in the right order. I'm pretty sure this has been talked about before but I can't find the thread. If someone could run down the order or point me to the right thread I'd appreciate it. Do I understand correctly, the scanner needs to be OFF when the doing the updates?
Quint-1-29
Gettysburg, PA
If you are using the EZ-Scan Program I would update each one separately
I have found that if you update all of them together one is bound to fail. This is just my experience with it. Yes, the Scanner has to off to check for updates and to install them. Oh the order of updating them would be the EZ-Scan Program first then the two firmware together then the remaining ones.
