Update Went Wrong.
TexScan780D
I updated my G5 to V1.3, loaded my program which is in Zone 1 to the G5, and now the G5 tells me Zone 1 Unprogrammed.
Steve
N6ML
Did you check all 8 knob positions? Are they all unprogrammed?
TexScan780D
I turned the knob to all the poistions and the G5 keeps stating Zone 1 Unprogrammed.
N6ML
OK, so, in PPS, on tab D6 (Zone & Channel Setting), you have knob positions in zone 1 programmed, and you have programmed the pager (click on "Program" at the bottom, then the Program button). PPS should report "Programming Successfully" (sic), and the pager should reboot. If you've done all of that (do it again to make sure).... maybe export and post your profile here?
TexScan780D
YES! Works now. thank you N6ML.
