Updated Feed, new sound issue on BCD996
Dwbrower
Ewing, NJ
I've put a BCD996XT scanner on my updated feed. I'm scanning between two groups a limited amount of channels. While scanning, I get click, click, click on the feed but if I have it on hold on a specific channel, no problem. WX and CloseCall are off and not an issu
Ubbe
Stockholm, Sweden
It's probably the sound from the audio before where it gets muted that are somehow imposed on the audio. You can probably solve that by attenuating the audio to the feed and increase the volume control, as I believe that the line out level are following the volume control. It can also be a too high setting of the audio AGC in the feed. It could be increasing the audio way too much when there is silence if you do not have a max setting of gain you can set. It depends of the feed software you are using what options you will have at hand.
/Ubbe
