Updated freqs for Clallam County / Forks, WA
Forks, WA
Our frequencies out here have changed from any listing I've been able to locate-- 159.030 isn't found anywhere but is used by our fire/rescue and the PD now uses 453.375-- again, not listed. Any help? Thanks.
RBMTS
WA Database Admin
Naperville, IL
As long as you have verified the frequency usage, submit the info to the database along with any additional info such as PL, repeater or simplex, dispatch, tac, or talk type of channel.
This is how the DB is updated.
Thanks!
