dmg1969
I updated the mounting location of my HP-1. I originally had it on top of the dash with the RAM mount held with SuperLock strips. Original install here:
http://forums.radioreference.com/pi...ile-setup/283388-homepatrol-mobile-setup.html
Although not ideal, it worked initially. Now that the warm and much sunnier weather is here, I find that it was getting far too much sun and becoming quite warm. That was not the case in the winter. I remove the HP-1 when I am at work, but it still becomes very warm to the touch while driving home on a bright sunny day...even with the AC on. Of course running the AC does nothing to alleviate the sun beating through the windshield.
I decided that the best location would be to the right of the shifter console, so I loosened the trim around the radio/climate control stack, removed shifter face plate and partially disassembled the wrap around the shifter console to make sure that I would not drill into anything. The only thing I had to avoid was a feed for the passenger side airbags. That was at least two inches away and I was using short, heavy screws, so I was fine. Here is the updated finished product.
