UPdated L-band (mostly INMARSAT) file.
dlwtrunked
I should find a web place to put this
  • LBand satelllites_2020.pdf
dlwtrunked
I had it done earlier but did not get around to putting it into a good format. Note that I do not hear some of the spot beams hear in Virginia but do see the data directing aircraft to use them.
dlwtrunked
I fixed a few minor typos that some seen in the new attachment.
Note that Ligado (formerly Lightwave) has FCC support for using 1526-1536, 1627.5-1637.5, and 1646.5-1656.5 MHz. this would potentially interfere in the US with the weak reception of the 1528 MHz frequencies (probably on spot beams directed to E ATL or Europe) in the list.
hamradionl
Hi to all,
Like asking about those many, many pulsed signals on inmarsat.
Anyone know what it is?
Or way to decode?
dlwtrunked
Do you have a copy of the current BB table data for 99W on 1545.0200MHz ?
Sorry I am months late in responding. It is in below (uninteresting parts deleted for size).
Note that the GES is HEX below (from JAERO); but "in reality", is is OCT and should be displayed as 3 digits so that the first indicates the region number (not the same as the satellite ID):
Region 0 is AORW, Region 1 is AORE, and Region 3 is AMER.
43(HEX) = 103(OCT) (Burum)
44(HEX) = 104(OCT) (Burum)
02(HEX) = 002(OCT) (Laurentides)
05(HEX) = 005(OCT) (Laurentides)
D0(HEX) = 320(OCT) (Pamaulu)
Multiple GES numbers in some region are used for legacy when more than one ground station was involved in the past.
99W/AORW and 97.5W/AMER actually are virtual satellites on the same physical satellite.
1545.015 (GES 43, Long 54W, Psmc1)
AES_system_table_broadcast_satellite_id_COMPLETE SATELLITE ID = 0 (Long 99W) Seq = 6 Psmc1 = 1545.0200MHz Psmc2 = 1545.2050MHz
AES_system_table_broadcast_satellite_id_COMPLETE SATELLITE ID = 1 (Long 54W) Seq = 5 Psmc1 = 1545.0150MHz Psmc2 = 1545.1950MHz
AES_system_table_broadcast_satellite_id_COMPLETE SATELLITE ID = 2 (Long 142.5E) Seq = 4 Psmc1 = 1545.2000MHz Psmc2 = 1545.0100MHz
AES_system_table_broadcast_satellite_id_COMPLETE SATELLITE ID = 3 (Long 24E) Seq = 3 Psmc1 = 1545.1900MHz Psmc2 = 1545.0050MHz
AES_system_table_broadcast_satellite_id_COMPLETE SATELLITE ID = 5 (Long 144E) Seq = 2 Psmc1 = 1545.1050MHz
AES_system_table_broadcast_satellite_id_COMPLETE SATELLITE ID = 6 (Long 25.5E) Seq = 1 Psmc1 = 1545.1150MHz
AES_system_table_broadcast_satellite_id_COMPLETE SATELLITE ID = 7 (Long 97.5W) Seq = 0 Psmc1 = 1545.1100MHz
AES_system_table_broadcast_GES_Psmc_and_Rsmc_channels_COMPLETE Seq = 1 GES = 43 --> Psmc = 1545.0150MHz (RX), Rsmc0 = 1646.5150MHz (TX), Rsmc1 = 1646.5500MHz (TX)
AES_system_table_broadcast_GES_Psmc_and_Rsmc_channels_COMPLETE Seq = 0 GES = 44 --> Psmc = 1545.1950MHz (RX), Rsmc0 = 1646.5950MHz (TX), Rsmc1 = 1646.5550MHz (TX)
P_R_channel_control_ISU GES = 43 Pd = 1546.070MHz at 10500bps
1545.020 (GES 05, Long 99W, Psmc1)
AES_system_table_broadcast_GES_Psmc_and_Rsmc_channels_COMPLETE Seq = 1 GES = 02 --> Psmc = 1545.2050MHz (RX), Rsmc0 = 1646.6650MHz (TX), Rsmc1 = 1646.6675MHz (TX)
AES_system_table_broadcast_GES_Psmc_and_Rsmc_channels_COMPLETE Seq = 0 GES = 05 --> Psmc = 1545.0200MHz (RX), Rsmc0 = 1646.6750MHz (TX), Rsmc1 = 1646.6775MHz (TX)
P_R_channel_control_ISU GES = 05 Pd = 1546.078MHz at 10500bps (actually 1546.0775)
1545.110 (GES D0, Long 97.5W, Psmc1)
AES_system_table_broadcast_GES_Psmc_and_Rsmc_channels_COMPLETE Seq = 0 GES = D0 --> Psmc = 1545.1100MHz (RX), Rsmc0 = 1646.6225MHz (TX), Rsmc1 = 1646.6250MHz (TX)
P_R_channel_control_ISU GES = D0 Pd = 1545.075MHz at 1200bps
P_R_channel_control_ISU GES = D0 Pd = 1546.020MHz at 10500bps
1545.195 (GES 44, Long 54W, Psmc2)
P_R_channel_control_ISU GES = 44 Pd = 1545.095MHz at 600bps
P_R_channel_control_ISU GES = 44 Pd = 1546.055MHz at 10500bps
1545.205 (GES 02, Long 99W, Psmc2)
