Updated library database for pro-107
gareee
Rockledge, FL.
When I am on the whistler download page, do I download just the Library_db files? There are 5 or 6 other files for the ws1080. My iscan card has just been configured from the Radio Shack Iscan download page. Do I have to download the Whistler scanner driver too? or just the Library files from Whistler?
I can't find my Pro 107 Digital DB folder. Do I have to insert my iscan card in the reader to get that folder? Sorry, I am not too bright with this stuff.
Open file explorer, open the documents folder, look for the iScan folder, look for the DB folder
wizzardproduction
Puerto Rico
iam gonna give this a try myself i have one brand new in the box i aquired from somewhere so heres goes nothing lol ill report back my findings
73s
wizzardproduction
Puerto Rico
ok i have a question i notice a bin file in the DB folder and one in the new whistler with all the DB files do i replace it with the new BIN file from the 1080 ?
gareee
Rockledge, FL.
It is not useless if you can follow directions on how to manually update the library data and want to listen to analog only.
You can obtain an updated library using the Whistler Handheld PC app for the ws1080, then transfer the DB files to your non supported iscan pc app.
Download and install ezscan for the WS1080 From whistlergroup.com Then run a library update.
Then on your PC go to My Document > Whistler 1080 Digital > DB and copy the contents of this folder.
Replace the files in your Pro-107 Digital DB folder with the files copied from the Whistler 1080 digital DB folder. Launch your RadioShack Iscan pc app and you will have the latest Library.
Question, I installed ezscan for the ws1080 from whistle group but, where do I run the library update?
gareee
Rockledge, FL.
I am sorry < I'm at a lost after I lost the cards memory and can't transfer the ws1080 library to the iscan DB files..Is there any way you can give me a step for step procedure on how to get this iscan card updated to run the pro 107?Now I even have problems with the actual radio shack scanner playlist to set the scan card up. When I downloaded the ezscan library, where do I go to update the library..?
gareee
Rockledge, FL.
its right up above listed step 1 step 2 and so forth scroll up i think is what your looking for
The question is: How do I find the page to update the Whistler library update after I downloaded the ezscan library?, On my documents, do I open the DB file or just right-click and copy to transfer to the my documents Iscan DB file, Now, how do I get those updated DB files to the Radio Shack Pro 107 Playlist page where I load the Iscan card or do I load the card from the Whistler's Playlist page?
gareee
Rockledge, FL.
That's the same problem I am having. Do I open the bin or just right click the whole file? I am sorry, I am a little weak going through throat cancer.
Wackyracer
It's NOT a bin file....it is a DB which is DATABASE.
gareee
Rockledge, FL.
As explained early, updates to the database are done through the iScan software on the Library Import tab, that is the only way, and then loaded into the scanner, once loaded into the scanner you can update through the scanner. There is no way to put the database into the scanner except through the iScan software.
Yelling at us by using bold text won't change the answer.
gareee
Rockledge, FL.
I wasn't yelling. Just wanted to make sure you noticed the post..
Wackyracer
Once you have (copied and pasted) the library DB you got from the ws1080 ver of ezscan (found in the My documents folder) into the iscan program files, you use iscan as before to do the updates or add more systems to your pro-107. But you must manually do these updates each week to stay current with any changes to the systems you monitor, as ISCAN will NO LONGER retrieve the library data base because the servers have been turned off.
gareee
Rockledge, FL.
Ok..Thank you.
wizzardproduction
Puerto Rico
ok i copied the db files from the downloaded file 1080 and replace them from the original pro107 db folder but it didnt work nothing happened period . but after installing the sd card into the computer i downloaded directly into the db folder onto the sd card deleting the origiginal files and it worked it appeared to when turning on scanner the library files seem to be updated but the iscan software still doesnt recognize the new db files ?
wizzardproduction
Puerto Rico
and yes theres db files and 1 bin file in the 1080 db file when unzipped and also in the db folder on computer and sd card
RFI-EMI-GUY
Can somebody point me to the latest database LIBRARY for the PRO-107? I also want to listen to Brevard and Volusia EDACS. I also would like the latest iSCAN Software Thanks In advance!
