It would be helpful to know what scanner you have and where you are located.but i see there updates in my state. is there any way to scan for changes in my list of channels.
What county?pro 651, michigan
pro 651
Scroll down to "Change History" at this link:bay, i see Saginaw updated but not sure what one to update with out copying all of them and deleting duplicates.
While this is not "scanning for updates" directly, you can find what changed by looking at your state in the database, then see if your county, or other ones near you or where you often go, are flagged with a color. If the county is shaded green, there has been an update of some sort in the last 24 hours. If a yellowish color, an update was done in the last 7 days. Pull up the county in the database & click on the link for it.pro 651, michigan
Looking at Bay County, the statewide trunked system, MPSCS, is the only system that had a change.bay, i see Saginaw updated but not sure what one to update with out copying all of them and deleting duplicates.
what that mean![]()
Pro-651 - The RadioReference Wiki
wiki.radioreference.com
FYI, "This scanner will not receive P25 Phase 2 signals. "
so the green is what been updated.Looking at Bay County, the statewide trunked system, MPSCS, is the only system that had a change.
The last update specifically in your county was back in April.
Reading the notes listed for updates to MPSCS, updates were done for Detroit, as well as Saginaw County
Scroll down to the talkgroups to get a view of what changed (partial screenshot below; updates for Saginaw were made yesterday, but still within 24 hours as of this post).
Exactly. Not sure specifically what changed, but I suspect that, if you have Saginaw programmed, if you look at the settings for those talkgroups, you likely will not find anything that needs to be modified to continue listening to those agencies.so the green is what been updated.
None of the MPSCS is Phase 2, yet.![]()
Talkgroups 119 and 120 weren't programmed in my scanner. They may be new or I missed them in an earlier update. I usually try to keep everything updated. The rest of the updated(green) ones were already programmed in my scanner.Exactly. Not sure specifically what changed, but I suspect that, if you have Saginaw programmed, if you look at the settings for those talkgroups, you likely will not find anything that needs to be modified to continue listening to those agencies.
The database admin probably made a change in something that is not directly visible when looking at the system, but has zero effect on how to program it.
