I just saw there were updates made to the database for North County Fire in San Diego county it shows the DEC. 80 for north zone tac 3 and 112 for north zone tac 4 is this right or were some numbers forgot?
It's because they're running out of analog TGs. A long time ago permanent analog TG assignments started at the NMA TG's. There were a few below them that were used temporarily for some organizations (CALTRANS, a school district) and for try-out radios.I've noticed some really low numbered new talkgroups are showing up on the RCS in recent submissions.
Judging by what's assigned in the database I wouldn't call what's available a large pool. You did run out of digital talkgroups hence the change of the third partition to digital (700-7FF) because I know it used to be 4x4. I see 021 to 031 available and then random unused or reused throughout the analog partitions.Gee, I'm not aware of any shortage of analog TGs (there's less than 2000 TGs in use on the system, and there are more than 2000 TG IDs available in the analog partition). We purely made a decision to use previously unused low numbers.
Skip, I don't think you understand how Motorola systems organize talkgroups. TGs when organized as digital or analog fall in to ranges on the system. The admin does not determine on a one-on-one basis whether a talkgroup is digital or analog. Typically these ranges follow the standard partition formatting Type I used, which is eight partitions, $*00(0)-$*FF(0). In laymen's (scannerist's) terms for TGs this is:
P0: 16 - 8176
P1: 8192 - 16368
P2: 16384 - 24560
P3: 24576 - 32752
P4: 32768 - 40944
P5: 40960 - 49136
P6: 49152 - 57328
P7: 57344 - 65504
These full ranges are only valid when digital is used. If you assign analog talkgroups and you use Priority Scanning, which the RCS does use, you may only use half the number ("every 32") per partition. At the moment the RCS is configured to use three partitions for analog and five (or three?) for digital. That is not equal to 4,094. That is roughly 2,560 digital TGs if using five partitions and roughly 766 analog if using three. Now considering this is an 800 system the TG range 8128-8176 may not be assigned for certain reasons. Look in the database and you'll see this gap.
The question is what the last two partitions are assigned for. They used to be digital but now could have been reassigned to analog. Only Don knows. But if assigned to analog that gives you around 500 more. So, OK, not exactly a shortage but at the rate the RCS assigns stuff it could be soon.
Alright Don.I don't mean to be a PITA and appreciate your participation here. It's great to know you have a handle on the system that your *ahem* predecessors did not.
