Casey
Folks I have new Phase II equipment and have been sending some updates in to the admin regarding the fairly new Georgia Tech Phase II Digital system. I have added the second control channel that was missing and it has been added to the database. The database currently contains the wrong RFSS and Site Info (you must have this correct in order to use a G4/G5 Unication unit and possibly some consumer grade scanners. The correct info is RFSS 10 and Site 10 if you aren't receiving the system using the old values of 1 and 001. I wanted to bounce that off the group before submitting. I am properly trunking the system now way off in Cobb county.
Also, sadly I believe I have to report Ga Tech PD has encrypted again...they moved over to the system from the Atlanta TRS (which was in the clear) and are currently encrypted on tg 351 (which is not in the database yet). I have NOT heard Georgia Tech PD on the Atlanta TRS lately so I don't think this is a coincidence. Also i'm getting an in the clear talkgroup is 301 (something to do with students) but I haven't listed enough to figure out what it is....it is not in the database yet either, wanted to wait and see what it could be. Again, you must have a phase II scanner to hear this system.Thoughts?
