electricsheep
Since the introduction on July 4th of the new NAED dispatch codes for the Edmonton Fire Rescue services, all dispatches now use the new system. Here's what I have captured so far for all calls for about the last month and a bit. Eventually I will get all the codes, but it will just take me a couple more weeks or maybe a month or so. There will always be elusive codes, and it appears the version of NAED codes the EFR are using are a little different from other NAED Fire codes I have on file.
Edmonton Fire Rescue Response Type Codes
ALARMS
52B1A ALARMS - RESIDENTIAL (MULTIPLE) - ALARM TROUBLE
52B1P ALARMS - RESIDENTIAL (MULTIPLE) - PULL STATION
52B1S ALARMS - RESIDENTIAL (MULTIPLE) - SMOKE DETECTOR
52B1U ALARMS - RESIDENTIAL (MULTIPLE) - UNKNOWN
52B2A ALARMS - RESIDENTIAL (SINGLE) - ALARM TROUBLE
52B2C ALARMS - RESIDENTIAL (SINGLE) - CO
52B2S ALARMS - RESIDENTIAL (SINGLE) - SMOKE DETECTOR
52B2U ALARMS - RESIDENTIAL (SINGLE) - UNKNOWN
52B3A ALARMS - NON DWELLING STRUCTURE - ALARM TROUBLE
52B5A ALARMS - UNKNOWN SITUATION - ALARM TROUBLE
52C1A ALARMS - HIGH LIFE HAZARD - ALARM TROUBLE
52C1S ALARMS - HIGH LIFE HAZARD - SMOKE DETECTOR
52C1U ALARMS - HIGH LIFE HAZARD - UNKNOWN
52C2A ALARMS - HIGH RISE - ALARM TROUBLE
52C2U ALARMS - HIGH RISE - UNKNOWN
52C3A ALARMS - COMMERCIAL STRUCTURE - ALARM TROUBLE
52C3H ALARMS - COMMERCIAL STRUCTURE - HALON
52C3S ALARMS - COMMERCIAL STRUCTURE - SMOKE DETECTOR
52C3T ALARMS - COMMERCIAL STRUCTURE - TEMP DETECTOR
52C3U ALARMS - COMMERCIAL STRUCTURE - UNKNOWN
52C3W ALARMS - COMMERCIAL STRUCTURE - WATERFLOW
CITIZEN ASSISTANCE
53A1 CITIZEN ASSIST/SER CALL-LOCKED IN VEH (NON-MED ASSIST)
53A2 CITIZEN ASSIST/SER CALL-CITIZEN ASSIST (NON-MED ASSIST)
53A3 CITIZEN ASSIST/SER CALL-CITIZEN ASSIST (NON-MED ASSIST)
53A4 CITIZEN ASSIST/SER CALL-ANIMAL RESCUE
53A5 CITIZEN ASSIST/SER CALL-WATER PROBLEM
53B1 CITIZEN ASSIST/SER CALL-LOCKED IN VEH (POSS MED ASSISTANCE)
53B3 CITIZEN ASSIST/SER CALL-CITIZEN ASSIST (POSS MED ASSIST)
53B4 CITIZEN ASSIST/SER CALL-UNKNOWN SITUATION (INV)
53C1 CITIZEN ASSIST/SER CALL-WATER PROB WITH ELEC HAZARD
CONFINED SPACE
54D1A CONF SPACE/ST COLLAPSE-ENTRAP (CON)-AVALANCHE
ELECTRICAL HAZARD
55A1 ELEC HAZARD-TRANS OUTSIDE (WIRE/POLE)
55B4 ELEC HAZARD-ELECTRICAL ODOR
55B5 ELEC HAZARD-UNKNOWN SITUATION (INV)
55C2 ELEC HAZARD-WIRES DOWN WITH SMOKE/ARCING
ELEVATOR RESCUE
56A1 TYPE: ELEV/ESC RESCUE-ELEVATOR MALFUNCTION (OCC INSIDE)
56B1 TYPE: ELEV/ESC RESCUE-ELEVATOR MALFUNC (OCC INSIDE-MED COND PR)
56B2 ELEV/ESC RESCUE-CAUGHT (ESCALATOR) WITH NO INJURIES
56B3 ELEV/ESC RESCUE-UNKNOWN SITUATION (INVESTIGATION)
56D1 ELEV/ESC RESCUE-ENTRAP (ESCALATOR) WITH INJURIES
EXPLOSION
57B3 EXPLOSION - UNKNOWN SITUATION (INVESTIGATION)
EXTRICATION
58D1 EXTRICATION/ENTRAP (MACH, VEH) - ENTRAP (CONFIRMED)
FUEL SPILL
59B1 FUEL SPILL - UNCONTAINED SPILL - 25-100 LITRES
59B2 FUEL SPILL - CONTAINED SPILL < 25 LITRES
59C1 FUEL SPILL - UNCONTAINED SPILL > 100 LITRES
59C3 FUEL SPILL - UNKNOWN SITUATION (INVESTIGATION)
GAS LEAK
60B1 GAS LEAK (NAT/LP GASES)-OUTSIDE TANK LEAK<20 LBS
60B2 GAS LEAK (NAT/LP GASES)-OUTSIDE ODOR
60C1 GAS LEAK (NAT/LP GASES)-OUTSIDE TANK LEAK > 20 LBS
60D1 GAS LEAK (NAT/LP GASES)-INSIDE RUPTURE/TK LEAK (ODOR)
60D2 GAS LEAK (NAT/LP GASES)-OUTSIDE RUPTURE (ODOR)
HAZMAT
61A1B HAZMAT - ABANDONED WASTE - BIOLOGICAL
61A1C HAZMAT - ABANDONED WASTE - CHEMICAL
61B1B HAZMAT - SMALL SPILL (< 25 LITRES) - BIOLOGICAL
61B1C HAZMAT - SMALL SPILL (< 25 LITRES) - CHEMICAL
61B1U HAZMAT - SMALL SPILL (< 25 LITRES) - UNKNOWN
61C1B HAZMAT (CONTAINED) - BIOLOGICAL
61C1C HAZMAT (CONTAINED) - CHEMICAL
61D1B HAZMAT - HAZMAT (UNCONTAINED/MOVING)-BIOLOGICAL
61D1C HAZMAT - HAZMAT (UNCONTAINED/MOVING)-CHEMICAL
LIGHTNING STRIKE
63B4 LIGHTNING STRIKE (INV) - OUTSIDE LIGHTNING STRIKE
MUTUAL AID
65A1 MUTUAL AID/ASSIST OUTSIDE AG-M/AID TO INC (SINGLE UNIT)
65A2 MUTUAL AID/ASSIST OUTSIDE AG-ASSIST OUTSIDE AG (SINGLE UNIT)
65B1 MUTUAL AID/ASSIST OUTSIDE AG-M/AID TO INC (SINGLE UNIT)
65B2H MUTUAL AID/ASSIST OUTSIDE AG-ASSIST OUTSIDE AG (SINGLE UNIT)-HAZMAT
65D1 MUTUAL AID/ASSIST OUTSIDE AG-M/AID TO INC (MULTIPLE UNITS)
INVESTIGATE ODOR
66A1 ODOR (STRANGE / UNKNOWN) - ODOR INSIDE
66A2 ODOR (STRANGE / UNKNOWN) - ODOR OUTSIDE
66C1 ODOR (STRANGE / UNKNOWN) - ODOR WITH PATIENTS
OUTSIDE FIRE
67A1 OUTSIDE FIRE - TRANSFORMER (WIRE/POLE)
67A2 OUTSIDE FIRE - EXTINGUISHED FIRE
67B1 OUTSIDE FIRE - SMALL OUTSIDE FIRE
67B1R OUTSIDE FIRE - SMALL OUTSIDE FIRE - RESIDENTIAL
67B1S OUTSIDE FIRE - SMALL OUTSIDE FIRE - STRUCTURE
67B1U OUTSIDE FIRE - SMALL OUTSIDE FIRE - UNKNOWN
67B2 OUTSIDE FIRE-SMALL O/SIDE FIRE (HAZMAT PR)
67B3 OUTSIDE FIRE - UNKNOWN SITUATION (INV)
67D1 OUTSIDE FIRE - WILDLAND FIRE
67D2 OUTSIDE FIRE - BRUSH / GRASS FIRE
67D3 OUTSIDE FIRE - LARGE OUTSIDE FIRE
INVESTIGATE SMOKE
68A1 INVESTIGATE SMOKE (OUTSIDE) - LIGHT SMOKE
68C1 INVESTIGATE SMOKE (OUTSIDE) - HEAVY SMOKE
STRUCTURE FIRE
69C1 STRUCTURE FIRE-APPLIANCE (CONTAINED)
69C2 STRUCTURE FIRE-EXTINGUISHED FIRE
69C2H STRUCTURE FIRE-EXTINGUISHED FIRE-HAZMAT
69D1 STRUCTURE FIRE-HIGH LIFE HAZARD
69D1S STRUCTURE FIRE-HIGH LIFE HAZARD-SMOKE ODOR
69D2 STRUCTURE FIRE-HIGH RISE
69D3 STRUCTURE FIRE-COMMERCIAL STRUCTURE
69D3H STRUCTURE FIRE-COMMERCIAL STRUCTURE-HAZMAT
69D4 STRUCTURE FIRE-RESIDENTIAL (MULTIPLE)
69D4S STRUCTURE FIRE-RESIDENTIAL (MULTIPLE)-SMOKE ODOR
69D5 STRUCTURE FIRE-RESIDENTIAL (SINGLE)
69D5S STRUCTURE FIRE-RESIDENTIAL (SINGLE)-SMOKE ODOR
69D8 STRUCTURE FIRE-SMALL NON-DWELL STRUC (BARN, S/BLDG)
69D9 STRUCTURE FIRE-MOB HOME, HSE TRAILER, PORT OFF
69D10 STRUCTURE FIRE-UNKNOWN SITUATION (INV)
VEHICLE FIRE
71A1 VEHICLE FIRE - (EXTINGUISHED)
71B1 VEHICLE FIRE
71C1 VEHICLE FIRE - THREATENING NON-STRUC
71D1 VEHICLE FIRE - WITH THREATENED STRUC
71D3 VEHICLE FIRE - LARGE FUEL/FIRE LOAD
71D3A VEHICLE FIRE - LARGE FUEL/FIRE LOAD VEH-ALT FUEL/HYBRID VEHICLE
WATER RESCUE
72B2 WATER RESCUE - UNKNOWN SITUATION (INVESTIGATION)
72E7RS WATER RESCUE - INLAND WATER RESCUE - RIVER SUMMER
MISC
90 NO APPLICABLE CODE
T01 TRAINING - AVAILABLE TO RESPOND
T02 TRAINING - NOT AVAILABLE TO RESPOND
T04 INSPECTION
T05 COMMUNITY EVENT - AVAILABLE TO RESPOND
T06 COMMUNITY EVENT-NOT AVAILABLE TO RESPOND
TEST TEST EVENT TYPE DO NOT DISPATCH
ALARMS
CITIZEN ASSISTANCE
CONFINED SPACE
ELECTRICAL HAZARD
ELEVATOR RESCUE
EXPLOSION
EXTRICATION
FUEL SPILL
GAS LEAK
HAZMAT
LIGHTNING STRIKE
MUTUAL AID
INVESTIGATE ODOR
OUTSIDE FIRE
INVESTIGATE SMOKE
STRUCTURE FIRE
VEHICLE FIRE
71B1 VEHICLE FIRE
WATER RESCUE
MISC
T04 INSPECTION
