Go Team Live Oak County - show newbies how it's done!
I ran DSD+ for a couple of days and came up with one additional voice channel for George West.
589 - 462.325.
I recorded TG 801, 3901 and 1904 being used and all of the voice record sound like oil field related activities; "turn on a heater" , "open valve to drain".
No LE or ISD seen other than the Karnes Co ISD already ID'd. I will check next week when spring break is over to see if there is any other school activity.
I monitored the LTR frequencies and heard a data burst that was about a second long about every 10 seconds on 452.4625 and a occasional approximate 7 second long burst, but only head on Sunday evening and never since.
Also setup to record the Corpus Christi freqs for Live Oak and only caught on ID being broadcast on 851.4625.
Bob
GREat job Bob you will have 6 more posts for a total of 12 before next week is even up !
So let's clarify If I understand you correctly on your site #3 freqs and their role playing observed so far:
389=CC primary and VC, 589=VC Voice Only never been a CC, 981=CC secondary and VC (see below)
003 (3) George West Live Oak (389)461.075c (589)462.325v (981)464.4250a (already submitted like this)
On my site #1 12=CC primary and VC, 15=CC secondary and VC, 18=VC Voice only never been a CC
So our 2 sites differ in that only my 1st & 2nd freqs rotate being the CC and your 1st & 3rd rotate as CC
001 (1) North Central San Antonio Bexar (12)451.0875c,(15)451.10625a,(18) 451.125v
TG 801 - I first saw this new 3/8/18 Fri 6:30pm & 10:31pm with RID=810 with alias of (3C C4) meaning ?
TG 1904 - I have not seen or heard this TG so far.
TG 3901 - School Buses w/ RID-3901=(Bus23) and 3904=(Bus17) (maybe additional TG for KCISD use ?)
ps ~ I can see another future blemish on Live Oak Countys squeaky clean RRDB page with the following:
New Trunking System Name: Industrial Communications (George West) - LTR Standard
LCN#?? 452.4625 (Hey at least it CWID's which should reveal it's LCN#? and if it's a HR Home Repeater)
Wildcard TG's Hit Counter=0 after a few weeks maybe its a dead horse or you may find a rare gem TG
FCC Lic WPSQ521 40W YG 451.300, 451.8375, 452.2125, 452.350. 452.4625 & 452.7500 (put em all)
So best tool would be one of your Pro-197's, manually setup a new LTR and add all 6 freqs on license
Make darn sure to check or enable "Auto Move" or LTR Auto Place feature and create a Wildcard TG etc.
During that hourly, bi-hourly CWID and or an active TG - your 197 will place 452.4625 in it's correct LCN#
I would start off by placing those 6 freqs from LCN#14 thru LCN#20 so that 1 thru 13 are wide open and
besides it will be much easier to notice say when all of a sudden 452.4625 becomes say LCN#2 example.
Sometimes depending on RX conditions you might manually sit on your newly created wildcard TG object
in this manually created LTR Standard TRS, press TSYS(F2), then press Analyz(F3), the scroll down to
the freq 452.4625 and just let it sit awaiting either an actuall active TG or usually a CWID or with our local
Industrial Communications LTR systems when the 7 sec idle data bursts hits the freqs LCN# is revealed
Next make sure that your Pro-197 Hit Count feature is enabled and heck even make the wildcard a FAV !
Also set a "Ring" alert with a flashing white LED mode tied to this new Wildcard TG to alert when active.
So set and forget it while you go to work and sleep. Then drill down once a day and check WC's hit count.
CWID's will not trip this count only new voice TG's and make sure if your right there to hit Store & label it.
Lastly, I saw these 100w freqs licensed to Corpus Christi 158.25 and 851.0125,851.5125 & 852.0125.
You said that you only caught on an automated CWID being broadcast on 851.4625 is this freq a typo ?
Also program these 4 freqs as conventional with yes maybe a beep alert with flashing Blue LED setting.
So are these 85x Mhz EDACS TRS freqs that might fill in the site gaps and belong to this fading system ?
I can't think of what these 85x freqs would belong to or were once planned to go to but the following TRS ?
Four County Coastal Bend Interoperational System Trunking System, Corpus Christi, Texas
How is this reply for a proper response ?
Well Bob that's a nice collection of scanners to blaze the trail in your Live Oak and surrounding counties
Wait for our dedicated DB admin rattlerbb01(Paul) to hit the trail next week w/a tapped BC785D & DSD+ !
Pretty sQQn this S&P NEXEDGE 303 is going to fly right by the S&P NEXEDGE 68 business network ...
and if an inside track source is correct it will be way more interesting monitoring consisting of LE TG's
