Updating the TRX-2
nezza
Hi everyone,
I am expecting to receive my TRX-2 shortly and would like to know what is the latest firmware version out at the moment?
Also, can someone explain to me in simple terms how to update to the latest firmware via EZ Scan and what "PC Driver" and "CPU Firmware Installer" are used for.
Thank you,
nezza
Machria
Long Island, NY
You do not need the CPU Firmware Installer. Just install the USB driver, which "activates" your USB port on your PC to accept and recognize the scanner when it's plugged in via the USB cable. Then install EZScan, and EZscan will do the upgrade for you. It will pop up and say "do you want to check for Upgrades"? Click yes, and after a few seconds it will show you what upgrades are available (scanner firmware, CPU firmware, and RR database). Basically, just click yes to all and let it upgrade, takes about 3 to 5 minutes.
It's very easy, don't sweat it. ;)
nezza
Thank you Machria for your detailed reply, it is much appreciated. It should arrive in a few days and the anticipation is killing me!
Thanks again.
