Upgrade Firmware
I have an HT1250 that I would like to upgrade the Firmware on. Can someone tell me what part's I need to do so? And if possible that part numbers would be appreciated.
Thanks,
Bob
I have the ribless prog. cable
I sorry I don't have any info on firmware parts and how to do it.
But I'm curious just what a firmware update will do for you?
I have some HT750's. Is there a reason for me to seek a firmware upgrade?
No reason except for the learning experience. Motorola Instructor-Led and even some of the online only training is quite pricey.
N1GTL
CT
Firmware is available for download on MOL. You need the cable, the firmware and the little special adapter to update your firmware. There is an adapter with a switch on that, I believe, changes the pinout on the 25 pin connector. You may be able to get a DB-9 to DB-25 adapter for the device to work OR they may offer a 9-pin adapter, I am not sure. The only one I have used is the 25 pin WITH a RIB. Once it is connected, you run the program and it updates the firmware. It is not rocket science. However, I have had a radio turn into a brick during a firmware upgrade. If you have no reason to upgrade, leave it alone. I think the newest firmware for the HT1250 is R05.12.02.
N1GTL
CT
res148cue said:
Is it the same cable for use with the CPS?
Yes, same cable. But as I mentioned, you need the firmware adapter.
gatekeep
FAIL 01/93
New York, NY
All that little adapter does, is ground the boot control (pin 12). I have made a home made connector out of a legit motorola RIB cable that just drops pin 12 to pin 16 (ground).
