You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
RadioReference.com Forums
Hi,
I have a Sangean ATS-803A and thinking about upgrading. Not sure if I will stick with a portable (Sangean 909X or Tecsun 880) or go for the Icon R-75.... Most likely the portable IF the results may be improved. I mostly listen to SW broadcast but sometimes a little ham radio.
Has anyone upgraded from the ATS-803A or DX440?
If so what did you upgrade to and what were the results?
It will connect to an external antenna, either in the attic or possibly under the eaves of the house.
